afriaazz
#1 Posted : Wednesday, June 21, 2017 2:48:50 PM(UTC)
afriaazz
i installed adobe ndi plugin from website but in my adobe after effect and adobe premier pro it dosnt shows ndi monitor in settings ..
kane
#2 Posted : Wednesday, June 21, 2017 10:28:12 PM(UTC)
kane
Are you saying the settings in Adobe product or NDI Monitor? You post doesn't make it clear what application you are looking at?
In Adobe Premiere, you need to go to the 'Edit' menu, then 'Preferences' finally, choose 'Playback' settings.
In that window, you will check the 'NewTek NDI Output' in both the Video and Audio devices areas.
For After Effects, the plug-in is automatic and shouldn't require any setup, but you might need to 'scrub' the timeline a frame or two to get it started outputting content.
Kane Peterson
NewTek
afriaazz
#3 Posted : Thursday, June 22, 2017 1:46:24 AM(UTC)
afriaazz
yea i Mean in Adobe Product ...... In Adobe Premiere, you need to go to the 'Edit' menu, then 'Preferences' finally, choose 'Playback' settings.
In that window, there is no 'NewTek NDI Output' options
rudyengels
#4 Posted : Thursday, June 22, 2017 2:42:49 AM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
Are you using Adobe Creative Cloud or an older version of Adobe Premiere? It only works with Adobe Creative Cloud.
fcl
#5 Posted : Tuesday, February 15, 2022 12:14:37 AM(UTC)
fcl
Switzerland
for us it is the same. In two PCs no NDI Output available with after effects 2022 and NDI tools 5 under Playback preferences.
