Since vmix has support for multiple outputs as well as multiple ndi outputs it would be cool to see a second preview/program engine available. This would be great for events where extra physical screens are involved that need a different mix signal or if using vmix call with multiple guests and switch the channels on the preview monitors for talent.
You can already do this.
Create a new input and customize your preview/program screen using the multiview function inside the input.
Then you can either use the "Fullscreen" function or "External" function to send out your custom preview/program screen.
