djevo1
#1 Posted : Friday, June 16, 2017 8:34:17 AM(UTC)
djevo1
Since vmix has support for multiple outputs as well as multiple ndi outputs it would be cool to see a second preview/program engine available. This would be great for events where extra physical screens are involved that need a different mix signal or if using vmix call with multiple guests and switch the channels on the preview monitors for talent.
mashynewie2
#2 Posted : Monday, June 26, 2017 8:02:18 AM(UTC)
mashynewie2
Was thanked: 44 time(s) in 33 post(s)
You can already do this.
Create a new input and customize your preview/program screen using the multiview function inside the input.
Then you can either use the "Fullscreen" function or "External" function to send out your custom preview/program screen.
