Broadcast Multiple Audio Track on Local Stream
hello, I have a conference in few months, it will have to be translated into 3 languages.
I think with 3 input in vMiw (3 microphones), i can mix this 3 tracks audio different in only one stream ? And the public choose desired audio track ?
Or then spread 3 different stream, and I select audio source per stream? eg. Stream 1 : Video + English ; Stream 2 : Video + Russian, ect.. I am in version 4K, last update (.50)
Thank you Regards
@ PhilippeR
Simple answer is NO, you cannot have 3 separate audio tracks in 1 Stream! You will have to do 3 Streams with 3 different encoders (as the vMix streamer does not yet provide multiple audio output options)
Hope that helps some.
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
we do it with one upload, video + master+bus a + bus b and in the server split and join the audios with the video, using this way we only need one computer/soft and one conection with a "small" uplink
