PhilippeR
#1 Posted : Wednesday, June 14, 2017 9:15:11 AM(UTC)
PhilippeR
hello,
I have a conference in few months, it will have to be translated into 3 languages.
I think with 3 input in vMiw (3 microphones), i can mix this 3 tracks audio different in only one stream ? And the public choose desired audio track ?
Or then spread 3 different stream, and I select audio source per stream?
eg. Stream 1 : Video + English ; Stream 2 : Video + Russian, ect..
I am in version 4K, last update (.50)
Thank you
Regards
#2 Posted : Wednesday, June 14, 2017 12:49:58 PM(UTC)
@ PhilippeR
Simple answer is NO, you cannot have 3 separate audio tracks in 1 Stream!
You will have to do 3 Streams with 3 different encoders (as the vMix streamer does not yet provide multiple audio output options)
Hope that helps some.
dark_ata
#3 Posted : Wednesday, June 14, 2017 1:48:38 PM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
we do it with one upload, video + master+bus a + bus b and in the server split and join the audios with the video, using this way we only need one computer/soft and one conection with a "small" uplink
