Showcase
Live recording of a band - Touchscreen
Thanks: 23 times Was thanked: 10 time(s) in 7 post(s)
Here´s a short "behind the scenes" clip of me doing a live cut for a band that friends of mine have... Oh yeah... it´s not always the "life of the rich and famous" ;-)
Thanks: 45 times Was thanked: 3 time(s) in 3 post(s)
Do you have a link to that touch screen you are using?
Don't have a link, but it's called HP 23" TM.
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ Harty
Awesome stuff! Perfect example of "best use" scenario for touch screen switching. Did you have any issues with the workflow and/or comments or concerns about it? Thanks for sharing.
@Icestream: No. Actually my system is running pretty stable. Sometimes when I add/delete new Inputs too quickly it may happen, that it reacts not very well or doesn't find an iput. But beside of that everything is running great. Latency is a bit of a problem when doing videowall stuff (when the wall is right on the stage), but i technically understand why that is, so I can deal with it...
Groups: Guests
So when you touch the input it goes to program? How do you change fade and cuts? ....really nice workflow.....I want to see the program out
You can control the behaviour of each input seperately. Some have a fade transition, others (the GoPro over the Drummer for example) have a cut transitiin. The stuff that i would cut to very fast gets no fades. You can see the Programme Out on the second monitor to my right.
Showcase
