Harty
#1 Posted : Thursday, June 8, 2017 11:05:45 AM(UTC)
Harty
Was thanked: 10 time(s) in 7 post(s)
Here´s a short "behind the scenes" clip of me doing a live cut for a band that friends of mine have...
Oh yeah... it´s not always the "life of the rich and famous" ;-)
al4video
#2 Posted : Thursday, June 8, 2017 1:15:23 PM(UTC)
al4video
Do you have a link to that touch screen you are using?
Harty
#3 Posted : Thursday, June 8, 2017 2:07:30 PM(UTC)
Harty
Don't have a link, but it's called HP 23" TM.
#4 Posted : Thursday, June 8, 2017 3:55:48 PM(UTC)
@ Harty
Awesome stuff!
Perfect example of "best use" scenario for touch screen switching.
Did you have any issues with the workflow and/or comments or concerns about it?
Thanks for sharing.
Harty
#5 Posted : Thursday, June 8, 2017 4:09:52 PM(UTC)
Harty
@Icestream: No. Actually my system is running pretty stable. Sometimes when I add/delete new Inputs too quickly it may happen, that it reacts not very well or doesn't find an iput. But beside of that everything is running great. Latency is a bit of a problem when doing videowall stuff (when the wall is right on the stage), but i technically understand why that is, so I can deal with it...
Digitalson
#6 Posted : Tuesday, June 13, 2017 3:03:17 PM(UTC)
Digitalson
Groups: Guests
So when you touch the input it goes to program? How do you change fade and cuts? ....really nice workflow.....I want to see the program out
Harty
#7 Posted : Tuesday, June 13, 2017 4:01:44 PM(UTC)
Harty
You can control the behaviour of each input seperately. Some have a fade transition, others (the GoPro over the Drummer for example) have a cut transitiin. The stuff that i would cut to very fast gets no fades. You can see the Programme Out on the second monitor to my right.
