clafarge
#1 Posted : Saturday, May 27, 2017 4:35:50 PM(UTC)
clafarge
Was thanked: 20 time(s) in 13 post(s)
Is it possible to:
1. Set up multiple vMix Call inputs
2. Save as a presets file
...then hours or days later:
3. Load the presets and email the invitation links with the Call password to each participant?
I have a setup I'd like to try that requires a lot of prep on each input, and it would be a big rush to implement everything right before a broadcast, and I currently don't have a license for multiple Calls, and not wanting to upgrade unless it's going to work.
Finally, when Google fails, where does one find coupons/promos for vMix?
Thank you!
Chad
#2 Posted : Saturday, May 27, 2017 5:28:20 PM(UTC)
Is it possible to:
yes
sunkast
#3 Posted : Saturday, May 27, 2017 11:12:38 PM(UTC)
sunkast
I do exactly this with a number of shows that have multiple guests via vMix Call. Most of these are regular hosts for a show so it's easiest to just save the preset and have them use the same password every week. Plus in some cases, I have adjusted the color balance for some guests. It all gets saved to a preset and is just like having a local camera input in vMix.
