vMix Call
VMixCall in Presets?
Joined: 5/27/2017(UTC) Posts: 93   Location: Greater St Louis Area Thanks: 67 times Was thanked: 20 time(s) in 13 post(s)
Is it possible to: 1. Set up multiple vMix Call inputs 2. Save as a presets file ...then hours or days later: 3. Load the presets and email the invitation links with the Call password to each participant?
I have a setup I'd like to try that requires a lot of prep on each input, and it would be a big rush to implement everything right before a broadcast, and I currently don't have a license for multiple Calls, and not wanting to upgrade unless it's going to work.
Finally, when Google fails, where does one find coupons/promos for vMix?
Thank you!
Chad
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Quote:Is it possible to: 1. Set up multiple vMix Call inputs 2. Save as a presets file ...then hours or days later: 3. Load the presets and email the invitation links with the Call password to each participant? yes
Thanks: 3 times Was thanked: 6 time(s) in 6 post(s)
I do exactly this with a number of shows that have multiple guests via vMix Call. Most of these are regular hosts for a show so it's easiest to just save the preset and have them use the same password every week. Plus in some cases, I have adjusted the color balance for some guests. It all gets saved to a preset and is just like having a local camera input in vMix.
vMix Call
