HWL1223
#1 Posted : Thursday, May 25, 2017 2:35:24 PM(UTC)
HWL1223
On 19.0.0.47; I can start a WMV stream OK. But when I stop the Record stream and try to change any parameter, I get a "streaming port is currently in use" error, even if no network connections are on/made. A reboot of vMix and subsequent change will fix this, but basically once a stream is started I cannot change a parameter without the reboot....
Ideas?
