Joined: 5/26/2013(UTC) Posts: 148  Location: Houston, TX, US Thanks: 28 times Was thanked: 6 time(s) in 6 post(s)
On 19.0.0.47; I can start a WMV stream OK. But when I stop the Record stream and try to change any parameter, I get a "streaming port is currently in use" error, even if no network connections are on/made. A reboot of vMix and subsequent change will fix this, but basically once a stream is started I cannot change a parameter without the reboot.... Ideas?
