JohanSpijker
#1 Posted : Sunday, May 21, 2017 5:33:34 AM(UTC)
JohanSpijker
Sometimes the camera settings jumps automaticly from SDI to HDMI. (BMD decklink mini recorder)
Is there a trigger-function available for that setting, so I can recall that function every time when i select that input.
[img][/img]
JohanSpijker attached the following image(s):
cam settings.JPG (41kb) downloaded 2 time(s).
#2 Posted : Sunday, May 21, 2017 5:47:00 AM(UTC)
AFAIK no
You have to make sure that BMD device is correctly set first and then you should not have a problem when adding this input into vMix
JohanSpijker
#3 Posted : Sunday, May 21, 2017 5:52:32 AM(UTC)
JohanSpijker
The cam inputs are working correctly and stable on SDI, but sometimes users call me (after a week they didn't use their system) that they doesn't have picture any more.
Then i have to explain that that have the change the setting again. So i hoped I could make a trigger function that force the cam input back to SDI in VMIX.
It is the Vmix setting that jumps, not the BMD settings !
#4 Posted : Monday, May 22, 2017 3:47:19 AM(UTC)
Just leave it to "Default" instead of picking HDMI or SDI. This way you should not have issues.
Similar Topics
Change camera input settings without closing and adding new input (General Discussion)
by m_elias 4/22/2020 7:35:24 AM(UTC)
