Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Sometimes the camera settings jumps automaticly from SDI to HDMI. (BMD decklink mini recorder) Is there a trigger-function available for that setting, so I can recall that function every time when i select that input. [img][/img] JohanSpijker attached the following image(s):  cam settings.JPG (41kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
AFAIK no You have to make sure that BMD device is correctly set first and then you should not have a problem when adding this input into vMix
The cam inputs are working correctly and stable on SDI, but sometimes users call me (after a week they didn't use their system) that they doesn't have picture any more. Then i have to explain that that have the change the setting again. So i hoped I could make a trigger function that force the cam input back to SDI in VMIX. It is the Vmix setting that jumps, not the BMD settings !
Just leave it to "Default" instead of picking HDMI or SDI. This way you should not have issues.
