livepad
#1 Posted : Saturday, May 13, 2017 11:20:48 AM(UTC)
livepad
Was thanked: 46 time(s) in 32 post(s)
Hi Folks.
Our NDI recording app for macOS and Linux (and perhaps windows..) is taking shape as a commercial product and we wanted to ask potential users what they needed to see.
The app features a web interface and captures NDI streams *natively* into a variety of formats including ProRes QuickTime movies, DNxHD files and MP4 H.264/AAC files.
If there are other formats you might find useful or other particular features you are looking for in a recorder, please let me know here, or email info @ ndi.cloud
Thanks.
NDI Apps at Sienna.tv
#2 Posted : Saturday, May 13, 2017 11:32:25 AM(UTC)
Hi Mark! Congrats!
first request: make it available for windows!
can you tell us about the hardware requirements/optimizations? supported linux distribs ?
Also the potential (simultaneous recordings - depending on hardware/codec combinations) in case you already have experimented this?
TIA
Guillaume
livepad
#3 Posted : Saturday, May 13, 2017 11:53:41 AM(UTC)
livepad
DWAM wrote:
Hi Mark! Congrats!
TIA
Guillaume
Hi Guillaume
We have already ported the basic app (which was developed on macOS) to Ubuntu 16.x and CentOS 7 (Red Hat) and it should be possible to get it onto Windows too if there is genuine demand. Given that NewTek already have a free NDI recorder for Windows, we may need some persuasion that there is a commercial opportunity for another Windows NDI recorder.
There are no specific system requirements except an X86 based computer which is basically NDI compatible (we don't plan to offer an ARM version at the moment). You don't need any fancy AVX type GPU stuff, so there may also be applications for this in cloud-based workflows using AWS or Azure.
The recorder is designed to operate in a multichannel mode. So far we haven't decided whether to make it just support 4 or 8 channels, or allow users to create as many parallel recordings as they want. Clearly we need to monitor CPU usage and somehow control the load - and that is all to be determined. As a very coarse guideline, I just recorded a 1080/50i NDI source into a ProRes quicktime movie, and it was using around 100% (out of 1600%) on a 2009 MacPro Tower (which has 2 x 2.66 GHz Quad-Core Intel Xeon - 16 hyper threads). So it might seem that 8 channels is pretty likely straightforward on a machine of this class, and probably more. Recording into H.264 is more CPU intensive and the same recording test used 300% (of 1600%) for MP4 (H.264/AAC) so you might only get 4 channels in that mode on this computer.
We may also decide to implement a RAM buffer (as we do with our professional base band recording system PictureReady) - since this would help to avoid dropping frames where the system or storage is starting to get loaded.
Thanks for your questions.
kricher1964
#4 Posted : Saturday, May 13, 2017 2:14:38 PM(UTC)
kricher1964
Was thanked: 13 time(s) in 4 post(s)
Mpg2 format would be useful for me in addition to the formats you already listed.
livepad
#5 Posted : Sunday, May 14, 2017 4:39:28 AM(UTC)
livepad
if you mean MPEG-2 Video and MPEG Layer 2 audio, then yes - this is already supported.
We will create a set of presets for common formats, so any other requested formats would be welcomed.
Currently we have:
MP4 file (H.264 / AAC)
MOV file (H.264 / AAC)
MOV file (ProRes, PCM audio)
MOV file (DNxHD, PCM audio)
MPG file (Mpeg2 Video, MPEG layer 2 audio)
Lennart
#6 Posted : Sunday, May 14, 2017 9:44:22 AM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
I'd be very interested in a Windows version. Do you know how the pricing will be?
kol0
#7 Posted : Monday, May 22, 2017 11:16:23 AM(UTC)
kol0
Rank:: Advanced Member
Was thanked: 8 time(s) in 8 post(s)
h265 / x265?
Guest (5)
