Recording Issues with Asus laptop
Joined: 8/24/2016(UTC) Posts: 19 Location: Olive Branch, MS
Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
I use vMix on 2 PC's and a Lenova laptop without any issues. I just acquired an ASUS G752V laptop and have loaded v19.0.46 on it. All functions work well except for the RECORD function. I create a directory for my recorded videos to go to, but when I try to record, I get the error message, "Recording Directory cannot be found" I have rebooted, deleted and recreated the directory several times but continue to get the same error message. I do not know if this is a vMix issue or an ASUS issue. Any ideas?
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
Check that you have the desired directory both in Settings/Recording and for Filename in Recording setup (the coq wheel left of the Record button, where one also specifies recording format)
 1 user thanked richardgatarski for this useful post.
Thanks, I changed the path in both areas and now my saved recording goes straight to the desktop and not to the assigned folder. That is a big step in the right direction and tells me that I have a problem with my path that I have typed in. Thanks again.
