Thanks: 1 times Was thanked: 6 time(s) in 5 post(s)
Hallo,
I tray connect vMix to asio driver but vMix can't see in in the list (settings -> audio). vMix doesn't support asio driver? My question is: How to get low audio latensy from the computer? Scheme is: MIC->SOUND CARD->HEADPHONES (when i talk to mic i hear delay in headphones). How to fix this?
Thanks for answer
Joined: 2/6/2011(UTC) Posts: 79 Location: Belgium Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
what is your sound card model?
I try m-audio Fast Track Ultra 8R and internal sound card.
Rank: Guest
Groups: Guests
would be awesome to have asio support on vmix... there`s a great app that i use, asio4all (http://www.asio4all.com/) VERY USEFULL
avoid if possible the use of your internal soundcard: apart from using it indeed with ASIO4ALL, it will always have a high latency. If you're using the M-Audio, you should be able to get (near-) zero latency using ist DSP based mixer on the monitor outputs. Going thru the PC would inevitably put some latency in the signal chain.
