artciukas
#1 Posted : Saturday, June 22, 2013 6:05:39 AM(UTC)
artciukas
Hallo,
I tray connect vMix to asio driver but vMix can't see in in the list (settings -> audio). vMix doesn't support asio driver?
My question is:
How to get low audio latensy from the computer? Scheme is:
MIC->SOUND CARD->HEADPHONES (when i talk to mic i hear delay in headphones). How to fix this?
Thanks for answer
Luc Henrion
#2 Posted : Saturday, June 22, 2013 6:22:44 AM(UTC)
Luc Henrion
what is your sound card model?
artciukas
#3 Posted : Saturday, June 22, 2013 6:41:46 AM(UTC)
artciukas
I try m-audio Fast Track Ultra 8R and internal sound card.
melody
#4 Posted : Saturday, June 22, 2013 6:44:01 AM(UTC)
Rank: Guest
Groups: Guests
would be awesome to have asio support on vmix... there`s a great app that i use, asio4all (http://www.asio4all.com/) VERY USEFULL
Luc Henrion
#5 Posted : Sunday, June 23, 2013 3:42:46 AM(UTC)
Luc Henrion
avoid if possible the use of your internal soundcard: apart from using it indeed with ASIO4ALL, it will always have a high latency. If you're using the M-Audio, you should be able to get (near-) zero latency using ist DSP based mixer on the monitor outputs. Going thru the PC would inevitably put some latency in the signal chain.
Similar Topics
higher audio latency vMix to vMix than vmix to Chrome (vMix Call)
by benwah 3/18/2021 8:35:50 AM(UTC)
How to approach audio latency? (General Discussion)
by davenv 9/14/2020 8:58:07 PM(UTC)
Managing Audio Latency (General Discussion)
by davenv 5/26/2020 2:12:55 AM(UTC)
NDI audio latency (NDI)
by Scott Barnett 4/2/2020 12:39:39 AM(UTC)
audio latency local recording to mp4 w/usb mic (General Discussion)
by graphicguy 1/13/2019 12:24:19 PM(UTC)
Audio Latency Dropouts only when VMIX window active (General Discussion)
by ckurtis 5/16/2017 8:57:54 AM(UTC)
ASIO Audio Latency (General Discussion)
by vhai 5/10/2016 8:00:15 PM(UTC)
by wjnesbitt 9/22/2014 9:06:34 PM(UTC)
