wkrasley
#1 Posted : Wednesday, April 26, 2017 3:01:11 PM(UTC)
wkrasley
Is it possible to have 2 versions of VMix on the same computer? I have one TV Talk show host that uses his laptop for power point and it is that old that I cannot use the desktop capture from version 7. I currently am using version 6 with no problems but like the features in the newest version. Maybe there is another way to capture the screen from his laptop? Thanks for your help.
#2 Posted : Wednesday, April 26, 2017 3:17:47 PM(UTC)
Hi
yes it's possible. Go to settings, tick show advanced settings options, go to options and tick allow multiple instances
Guillaume
wkrasley
#3 Posted : Wednesday, April 26, 2017 3:54:08 PM(UTC)
wkrasley
I only want to use 1 version at a time. When Tom has his show, I need to use VMix 16 (I said 6 and meant 16, also said 7 and meant 17)for his show and want to use VMix 17 or greater for the rest of the shows. Sorry, needed to clarify that.
#4 Posted : Wednesday, April 26, 2017 3:59:49 PM(UTC)
OK. Then you can install another previous version in another directory
wkrasley
#5 Posted : Wednesday, April 26, 2017 4:43:24 PM(UTC)
wkrasley
Thanks for the info. I wasn't sure if I could do it or not.
