wtmuradiotv
#1 Posted : Monday, April 24, 2017 3:12:47 PM(UTC)
wtmuradiotv
AddNewInput.INPUT_CAPTURE
This pin cannot use the supplied media type
Ok so since vmix has updated since i had it now some cams i am getting a error message as of the above .Can someone explain to me why this is happening .Nothing has changed since i been using vmix and as for the cams they haven't either so why now and what can be done to fix this issue
kjones9999
#2 Posted : Monday, April 24, 2017 3:59:21 PM(UTC)
kjones9999
Would seem to be an issue with Direct X. I would roll back any OS updates and see if that makes a difference.
