Joined: 7/4/2015(UTC) Posts: 65   Thanks: 3 times Was thanked: 3 time(s) in 3 post(s)
AddNewInput.INPUT_CAPTURE This pin cannot use the supplied media type
Ok so since vmix has updated since i had it now some cams i am getting a error message as of the above .Can someone explain to me why this is happening .Nothing has changed since i been using vmix and as for the cams they haven't either so why now and what can be done to fix this issue
Would seem to be an issue with Direct X. I would roll back any OS updates and see if that makes a difference.
