	Feature Requests
	Enable/disable triggers via scripting
 Joined: 1/15/2017(UTC) Posts: 45 Location: Exeter, UK
  Thanks: 17 times Was thanked: 1 time(s) in 1 post(s)
                Would like to be able to enable and disable triggers via scripting. Even better would be to add and delete.
  Alex
 Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
                Hi Alex
  I think that everything that can be done with triggers can also be done by scripting. So maybe if you really need this, you should use scripts only to avoid this need.
  Guillaume
	Feature Requests
