bitpod
#1 Posted : Monday, April 10, 2017 4:48:45 AM(UTC)
bitpod
Would like to be able to enable and disable triggers via scripting. Even better would be to add and delete.
Alex
#2 Posted : Saturday, April 15, 2017 2:43:43 AM(UTC)
Was thanked: 794 time(s) in 589 post(s)
Hi Alex
I think that everything that can be done with triggers can also be done by scripting. So maybe if you really need this, you should use scripts only to avoid this need.
Guillaume
stigaard on 4/22/2017(UTC)
