Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
HI !
ist it possible to use more than one Intensity Shuttle Thunderbolt At the same time ? imagine a system using a apple imac using windows 7 or 8 pro 64 bits, and 4 or 5 Intensity Shuttle Thunderbolt connected at the same time with 4 HD cameras using the HDMI interface ports ?
Best regards,
PFBM
Rank: Staff
Groups: Registered, Administrators Joined: 12/13/2012(UTC) Posts: 242 Location: Gold Coast, Australia
Thanks: 7 times Was thanked: 159 time(s) in 72 post(s)
Hi, Yes if the computer has more than one thunderbolt port, then you can use more than one Intensity Shuttle. However, you will only find Mac's have a maximum of two thunderbolt ports.
Rank: Staff
Yes that's right, some are starting to offer more than one. I have yet to see more than 2 however.
