PFBM
#1 Posted : Saturday, June 15, 2013 6:24:13 AM(UTC)
PFBM
HI !
ist it possible to use more than one Intensity Shuttle Thunderbolt
At the same time ?
imagine a system using a apple imac
using windows 7 or 8 pro 64 bits,
and 4 or 5 Intensity Shuttle Thunderbolt
connected at the same time with 4 HD cameras using the HDMI interface ports ?
Best regards,
PFBM
vmixsupport
#2 Posted : Monday, June 17, 2013 7:53:51 PM(UTC)
vmixsupport
Rank: Staff
Groups: Registered, Administrators
Was thanked: 159 time(s) in 72 post(s)
Yes if the computer has more than one thunderbolt port, then you can use more than one Intensity Shuttle. However, you will only find Mac's have a maximum of two thunderbolt ports.
ovinas
#3 Posted : Tuesday, June 18, 2013 12:55:55 AM(UTC)
ovinas
There are some mainboards that have more than one thunderbolt port.
http://www.gigabyte.de/p...ct-page.aspx?pid=4280#ov
vmixsupport
#4 Posted : Wednesday, June 19, 2013 8:41:48 PM(UTC)
vmixsupport
Rank: Staff
Yes that's right, some are starting to offer more than one. I have yet to see more than 2 however.
