Feature Requests
Large digital watch and direct function buttons
Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
Congratulating the vMix team for the great work they do. - A request that I find elementary also is that a large digital clock is added, somewhere quite visible. - If you can add a button (5,8,10 buttons, etc.) that are configurable to add any direct function. Thank you.
Joined: 2/18/2014(UTC) Posts: 1,844 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Hi JAIRODJ, To begin with, it is always a good idea to search the forum for similar requests before adding one ;) Quote:A request that I find elementary also is that a large digital clock is added, somewhere quite visible. I, and many other users, agree. Please see Production Clocks feature requestQuote:If you can add a button (5,8,10 buttons, etc.) that are configurable to add any direct function. Thank you. Could you please check out the Feature Request Stereoids for shortcuts: soft, virtual, and named. Perhaps your button need could be solved by having sort of Inputs as Buttons. If not, consider making a more detailed description of what you need buttons for, and how such a request would be implemented. Also, note that when you write with large letters it is frequently inpterperted as YOU ARE SHOUTING.
Feature Requests
