JAIRODJ
#1 Posted : Wednesday, April 5, 2017 9:58:47 PM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Congratulating the vMix team for the great work they do.
- A request that I find elementary also is that a large digital clock is added, somewhere quite visible.
- If you can add a button (5,8,10 buttons, etc.) that are configurable to add any direct function.
Thank you.
richardgatarski
#2 Posted : Thursday, April 6, 2017 2:52:40 AM(UTC)
richardgatarski
Hi JAIRODJ,
To begin with, it is always a good idea to search the forum for similar requests before adding one ;)
I, and many other users, agree. Please see Production Clocks feature request
Thank you.
Could you please check out the Feature Request Stereoids for shortcuts: soft, virtual, and named. Perhaps your button need could be solved by having sort of Inputs as Buttons. If not, consider making a more detailed description of what you need buttons for, and how such a request would be implemented.
Also, note that when you write with large letters it is frequently inpterperted as YOU ARE SHOUTING.
