GoGo
#1 Posted : Wednesday, April 5, 2017 11:41:01 AM(UTC)
GoGo
I was wondering, are there any USB/THUNDERBOLT 3 HMDI CAPTURE CARDS with more than one input. I have three Camcorders with HMDI and I would like a Capture Card that I can connect all three cameras.
I have the Asus - ROG Strix GL702 17.3"
TV97
#2 Posted : Wednesday, April 5, 2017 12:05:44 PM(UTC)
TV97
Guadeloupe
Was thanked: 10 time(s) in 5 post(s)
AkiTio Thunder3 PCIe Expansion Box + Magewell Pro Capture Quad HDMI Card (4-Channel)
thanks 1 user thanked TV97 for this useful post.
GoGo on 4/11/2017(UTC)
#3 Posted : Wednesday, April 5, 2017 12:24:04 PM(UTC)
You can also use a 4 SDI input capture card with HDMI2SDI converters which has the advantage of allowing longer cables than HDMI
BMD Decklink Duo2 is known to work well with Sonnet Thunderbolt 3 Echo Express SE1
