Hardware Compatibility
(Needed) CAPTURE CARD WITH MORE THAN 1 HMDI Connection
Joined: 3/10/2017(UTC) Posts: 63 Location: Philadelphia
Thanks: 51 times Was thanked: 1 time(s) in 1 post(s)
I was wondering, are there any USB/THUNDERBOLT 3 HMDI CAPTURE CARDS with more than one input. I have three Camcorders with HMDI and I would like a Capture Card that I can connect all three cameras.
I have the Asus - ROG Strix GL702 17.3"
Joined: 10/19/2016(UTC) Posts: 29  Location: Guadeloupe Thanks: 16 times Was thanked: 10 time(s) in 5 post(s)
AkiTio Thunder3 PCIe Expansion Box + Magewell Pro Capture Quad HDMI Card (4-Channel)
 1 user thanked TV97 for this useful post.
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
You can also use a 4 SDI input capture card with HDMI2SDI converters which has the advantage of allowing longer cables than HDMI
BMD Decklink Duo2 is known to work well with Sonnet Thunderbolt 3 Echo Express SE1
