Desktop capture input of Powerpoint is poor resolution and delayed
Hello everyone, I am a new user of vMix. So far I love it. However, Im having trouble with the desktop capture input. I am running my desktop capture over my wifi network (maybe this is the problem). My laptop is a macbook Air (this is running the vMix desktop capture and PowerPoint). My desktop in PC (this is running vMix).
The Powerpoint is pixelized and delayed. How do I achieve the following results: -A higher quality PowerPoint mix -No delay
Thanks for the help!
WLan can be the culprit. Just test it wired once to see if it makes any difference, but i'm almost sure it will.
macjaeger wrote:WLan can be the culprit. Just test it wired once to see if it makes any difference, but i'm almost sure it will. I picked up a network cable and connected my MacBook to PC. How do I configure the computers so vMix id's the ip address of my mac? Thanks for any help
Don't you have a switch/router/anything to put in between? Connecting two computers directly requires a special (crossover) cable!
