wkroeplin
#1 Posted : Sunday, June 9, 2013 11:16:24 AM(UTC)
wkroeplin
Hello everyone,
I am a new user of vMix. So far I love it. However, Im having trouble with the desktop capture input.
I am running my desktop capture over my wifi network (maybe this is the problem). My laptop is a macbook Air (this is running the vMix desktop capture and PowerPoint). My desktop in PC (this is running vMix).
The Powerpoint is pixelized and delayed.
How do I achieve the following results:
-A higher quality PowerPoint mix
-No delay
Thanks for the help!
macjaeger
#2 Posted : Sunday, June 9, 2013 5:08:21 PM(UTC)
macjaeger
WLan can be the culprit. Just test it wired once to see if it makes any difference, but i'm almost sure it will.
wkroeplin
#3 Posted : Thursday, June 13, 2013 11:29:51 PM(UTC)
wkroeplin
I picked up a network cable and connected my MacBook to PC. How do I configure the computers so vMix id's the ip address of my mac?
Thanks for any help
macjaeger
#4 Posted : Friday, June 14, 2013 8:33:33 AM(UTC)
macjaeger
Don't you have a switch/router/anything to put in between? Connecting two computers directly requires a special (crossover) cable!
Guest (4)
