mmorlan62
#1 Posted : Wednesday, June 5, 2013 11:54:47 AM(UTC)
mmorlan62
Was thanked: 7 time(s) in 5 post(s)
Hi there,
I've been experimenting with streaming to YouTube Live Events and receive a low-quality warning from YouTube. Here's their message:
"Please use a keyframe frequency of 2 seconds or less. Keyframes are not being sent often enough, this will cause buffering. Current keyframe frequency: 5.0 seconds. GOP sizes can be wrong if you have ingestion errors."
How do I adjust the keyframe frequency with vMix streaming?
Thanks,
Michael
cutter07
#2 Posted : Wednesday, June 5, 2013 6:49:42 PM(UTC)
cutter07
Look for a file profile.xml under C:\Program Files (x86)\vMix2012\streaming
and edit the file
Code:
        <advanced>
            <profile>Main</profile>
            <level>3.1</level>
            <keyframe_frequency>5 Seconds</keyframe_frequency>
        </advanced>
thanks 1 user thanked cutter07 for this useful post.
mmorlan62 on 6/6/2013(UTC)
mmorlan62
#3 Posted : Thursday, June 6, 2013 8:59:18 AM(UTC)
mmorlan62
Brilliant! Thank you.
enigmothy
#4 Posted : Wednesday, February 25, 2026 7:16:15 AM(UTC)
enigmothy
Rank:: Member
Is this the same file to adjust the keyframes for video recording as well? I'm thinking about anchor frame distance for mp4 recordings.
