How does one set the streaming keyframe duration?
Joined: 1/23/2013(UTC) Posts: 65  Thanks: 3 times Was thanked: 7 time(s) in 5 post(s)
Hi there,
I've been experimenting with streaming to YouTube Live Events and receive a low-quality warning from YouTube. Here's their message:
"Please use a keyframe frequency of 2 seconds or less. Keyframes are not being sent often enough, this will cause buffering. Current keyframe frequency: 5.0 seconds. GOP sizes can be wrong if you have ingestion errors."
How do I adjust the keyframe frequency with vMix streaming?
Thanks,
Michael
Joined: 6/2/2012(UTC) Posts: 103  Location: Germany Thanks: 13 times Was thanked: 10 time(s) in 9 post(s)
Look for a file profile.xml under C:\Program Files (x86)\vMix2012\streaming and edit the file Code: <advanced>
<profile>Main</profile>
<level>3.1</level>
<keyframe_frequency>5 Seconds</keyframe_frequency>
</advanced>
 1 user thanked cutter07 for this useful post.
Joined: 2/22/2020(UTC) Posts: 19  Location: Colorado Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Is this the same file to adjust the keyframes for video recording as well? I'm thinking about anchor frame distance for mp4 recordings.
