3rd Party Software and Development
Need simple script to combine dynamic values & inputs
Joined: 11/21/2017(UTC) Posts: 124  Location: Philadephia, PA Thanks: 31 times Was thanked: 14 time(s) in 9 post(s)
I know that this can be done in VB.net, but I don't know how to do it - so I'm hoping that it can be done in WebScripting - or that you can provide a simple example in VB.net script.
I'd like to combine DynamicValue1,DyamicInput2 into a single statement (including the comma) that substitutes the actual values for the two variables - rather than the string "DyamicValue1,DynamicInput" itself. Is there some function that will do that?
Thanks.
-David
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: David_in_Philly  I know that this can be done in VB.net, but I don't know how to do it - so I'm hoping that it can be done in WebScripting - or that you can provide a simple example in VB.net script.
Thanks.
-David DynamicInputs and DynamicValues are technically to be used by name directly into functions as separate variables/elements If one wants their content to be used in a different way , like combine their content, one needs to read them from the API XML to manipulate them to be used in a function or otherwise
Thanks, Doggy. Will be responding to your email later today.
Joined: 7/6/2020(UTC) Posts: 15  Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
Here you go. Code:
dim Dynamic1Val as String = ""
dim Dynamic2Val as String = ""
dim VmixXML as new system.xml.xmldocument
VmixXML.loadxml(API.XML)
dim Dynamic1Node As XmlNode = VmixXML.selectSingleNode("/vmix/dynamic/value1")
dim Dynamic2Node As XmlNode = VmixXML.selectSingleNode("/vmix/dynamic/value2")
Dynamic1Val = Dynamic1Node.InnerText
Dynamic2Val = Dynamic2Node.InnerText
dim Result As String=Dynamic1Val & "," & Dynamic2Val
console.writeline(Result)
