David_in_Philly
#1 Posted : Friday, December 31, 2021 1:33:01 PM(UTC)
David_in_Philly
Was thanked: 14 time(s) in 9 post(s)
I know that this can be done in VB.net, but I don't know how to do it - so I'm hoping that it can be done in WebScripting - or that you can provide a simple example in VB.net script.
I'd like to combine DynamicValue1,DyamicInput2 into a single statement (including the comma) that substitutes the actual values for the two variables - rather than the string "DyamicValue1,DynamicInput" itself. Is there some function that will do that?
Thanks.
-David
#2 Posted : Friday, December 31, 2021 6:12:09 PM(UTC)
Thanks.
-David
DynamicInputs and DynamicValues are technically to be used by name directly into functions as separate variables/elements
If one wants their content to be used in a different way , like combine their content, one needs to read them from the API XML to manipulate them to be used in a function or otherwise
David_in_Philly
#3 Posted : Saturday, January 1, 2022 11:40:21 AM(UTC)
David_in_Philly
Thanks, Doggy.
Will be responding to your email later today.
Kristoph
#4 Posted : Monday, February 21, 2022 10:05:11 PM(UTC)
Kristoph
Here you go.
Code:
dim Dynamic1Val as String = ""
dim Dynamic2Val as String = ""
dim VmixXML as new system.xml.xmldocument
VmixXML.loadxml(API.XML)
dim Dynamic1Node As XmlNode = VmixXML.selectSingleNode("/vmix/dynamic/value1")
dim Dynamic2Node As XmlNode = VmixXML.selectSingleNode("/vmix/dynamic/value2")
Dynamic1Val = Dynamic1Node.InnerText
Dynamic2Val = Dynamic2Node.InnerText
dim Result As String=Dynamic1Val & "," & Dynamic2Val
console.writeline(Result)
