h2video.nl
#1 Posted : Wednesday, February 9, 2022 4:18:27 AM(UTC)
h2video.nl
Rank:: Advanced Member
Just upgraded to latest vmix 24 and did some tests (windows 11 - TB4 BM mini recorder: all is well!!)
I did some start - stop - start tests and noticed only one recording in the recording directory. Did some more tests and found the previous recoring is overweritten!!
This has never happened to me before: I regularly stop-start recordings at an interlude or break / change - just to be sure the recording is saved and as a marker.
But now this would mean the previous recording is deleted!!
Bug? - Setting?
Note recording was in MP4 - HEVC with setting start new every 30 minutes (but only tested 1 minute...
cheers
Stefan
h2video.nl
#2 Posted : Wednesday, February 9, 2022 4:40:20 AM(UTC)
h2video.nl
to add to this:
did a quick test and noticed I used capital MM for minutes (just at 2 minutes past the hour) - this should be mm for minuts otherwise it writes 02 for the month February.
Added a seconds counter (ss) to the file format - so now the file name is unique and the previous file is not overwritten.
STILL: this should be noted! a recording should never be overwritten without a warning! If you make a mistake with the settings then you might be in for a suprise.
So a file overwrite warning maybe?
Stefan
#3 Posted : Wednesday, February 9, 2022 3:44:39 PM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
This is working exactly as intended.
Note if you change a setting, you should first understand what that setting does and test it prior to a production.
#4 Posted : Wednesday, February 9, 2022 4:41:36 PM(UTC)
i don't know, one could want that intentionally
h2video.nl
#5 Posted : Wednesday, February 9, 2022 6:11:20 PM(UTC)
h2video.nl
That's exactly what I was doing, Martin: testing prior to production.
I never understood it is intentional to have files overwritten in a stop-start action (if you do not give it a unique time code marker in the name). Overwriting files without warning is a risk, always.
anyway: thanks.
Stefan
h2video.nl
#6 Posted : Wednesday, February 9, 2022 6:13:26 PM(UTC)
h2video.nl
Warning in the manual maybe ;-)
it standard expectation because most other programs give that warning...
#7 Posted : Wednesday, February 9, 2022 6:20:39 PM(UTC)
Who reads a manual ? ;-)
Agree if optional
