Fabiano
#1 Posted : Tuesday, February 8, 2022 4:00:49 AM(UTC)
Fabiano
Brazil
I'm trying to capture these values ​​and add to the timer does anyone have an idea how to do it?
dim txA as string = Input.Find("vMIX_VARIAVEIS.xaml").Text("COUNTHORA01")
dim txB as string = Input.Find("vMIX_VARIAVEIS.xaml").Text("COUNTHORA02")
dim txC as string = Input.Find("vMIX_VARIAVEIS.xaml").Text("COUNTHORA03")
API.Function ("ChangeCountdown",Input:=1,Value:="txA:txB:txC")
#2 Posted : Tuesday, February 8, 2022 4:29:19 AM(UTC)
slapping something together what looks like code is not going to work
I advice you to do some research on vb.net programming
the timer is one string like 00:00:00
In your case based on the little information given you need to build a string from your element you retrieved first before one can use it as a value for the function ( or build the string within the function Value detail)
As it stands you value is exactly this: txA:txB:txC instead of something like 02:15:32 ( if txA=02 ; txB = 15 and txC = 32)
Kristoph
#3 Posted : Tuesday, March 1, 2022 2:40:10 AM(UTC)
Kristoph
What values are you actually trying to capture??
#4 Posted : Tuesday, March 1, 2022 3:20:48 AM(UTC)
Pretty obvious ;-)
3 different string values from a title to combine into a (time)string for a countdownchange but missing the concept of Concatenation of string variables with strings into one string.
Hence the advice to do some research on vb.net programming (giving a fish versus teaching to fish).
WaltG12
#5 Posted : Tuesday, March 1, 2022 4:03:11 AM(UTC)
WaltG12
In this scenario, you're doing neither.
thanks 1 user thanked WaltG12 for this useful post.
Fabiano on 3/4/2022(UTC)
#6 Posted : Tuesday, March 1, 2022 4:16:50 AM(UTC)
Yes i am sorry i forgot some links
https://forums.vmix.com/...86-Scripting-for-Dummies (has examples in use)
https://thedeveloperblog...bnet/string-concat-vbnet
Kristoph
#7 Posted : Tuesday, March 1, 2022 5:58:20 PM(UTC)
Kristoph
Mate not sure if you realise it, but 90% of your answers on this forum start with rude comments.
Sort it out.
KMA
Pretty obvious ;-)
thanks 1 user thanked Kristoph for this useful post.
Roy Sinclair
#8 Posted : Thursday, March 3, 2022 8:24:31 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Concatenation in VB is done using "+"
So txA + txB + txC will concatenate those three variables.
thanks 1 user thanked Roy Sinclair for this useful post.
Travis9577
#9 Posted : Thursday, March 3, 2022 10:22:14 PM(UTC)
Travis9577
#10 Posted : Thursday, March 3, 2022 10:47:17 PM(UTC)
Same link as above (see step 3) https://thedeveloperblog.com/vbnet/string-concat-vbnet
Fabiano
#11 Posted: : Friday, March 4, 2022 4:28:11 AM(UTC)
Fabiano
Brazil
excuse my ignorance, I graduated in programming technician around the year 1999 but I didn't work in the area, I did it because I like programming
But I don't work in the area, I'm in civil engineering, in the pandemic I moved to a company that uses Vmix, so I've already done a lot of automation with the little knowledge I have and with the help here.
I studied the topics, which led me to do a lot of things.
I'm not looking for FISH, I'm asking for help to solve a problem and an idea that I had here at work, that's all.
If anyone can help, great, I'm grateful, but if you don't have the availability or desire, just say nothing, sending me to study programming is not helping at all.
I AM VERY GRATEFUL TO EVERYONE WHO TRYING TO HELP...
THANK YOU VERY MUCH
Fabiano
#12 Posted : Friday, March 4, 2022 4:34:30 AM(UTC)
Fabiano
Brazil
I can capture the values that are in a gt title, example: txA=01 txB=15 txC=00
What I need is to take these values and transform into
txA:txB:txC = 01:15:00
Take these values and format as time
I can capture these values, I just can't join them in time format
Fabiano
#13 Posted : Friday, March 4, 2022 7:05:01 AM(UTC)
Fabiano
Brazil
Consegui. Obrigado pela atenção de todos
I achieved. Thank you all for the attention
API.Function("SetText",Input:="65",SelectedName:="Message",Value:=txA+":" + txB+":" + txC)
Guest (4)
