Capture values and change timer
Joined: 2/24/2021(UTC) Posts: 8  Location: São Paulo Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
I'm trying to capture these values and add to the timer does anyone have an idea how to do it?
dim txA as string = Input.Find("vMIX_VARIAVEIS.xaml").Text("COUNTHORA01") dim txB as string = Input.Find("vMIX_VARIAVEIS.xaml").Text("COUNTHORA02") dim txC as string = Input.Find("vMIX_VARIAVEIS.xaml").Text("COUNTHORA03")
API.Function ("ChangeCountdown",Input:=1,Value:="txA:txB:txC")
Joined: 12/27/2012(UTC) Posts: 5,530  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Fabiano  I'm trying to capture these values and add to the timer does anyone have an idea how to do it?
API.Function ("ChangeCountdown",Input:=1,Value:="txA:txB:txC") slapping something together what looks like code is not going to work I advice you to do some research on vb.net programming the timer is one string like 00:00:00 In your case based on the little information given you need to build a string from your element you retrieved first before one can use it as a value for the function ( or build the string within the function Value detail) As it stands you value is exactly this: txA:txB:txC instead of something like 02:15:32 ( if txA=02 ; txB = 15 and txC = 32)
Joined: 7/6/2020(UTC) Posts: 15  Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
What values are you actually trying to capture??
Originally Posted by: Kristoph  What values are you actually trying to capture?? Pretty obvious ;-) 3 different string values from a title to combine into a (time)string for a countdownchange but missing the concept of Concatenation of string variables with strings into one string. Hence the advice to do some research on vb.net programming (giving a fish versus teaching to fish).
Joined: 7/4/2021(UTC) Posts: 428  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Originally Posted by: doggy  giving a fish versus teaching to fish In this scenario, you're doing neither.
 1 user thanked WaltG12 for this useful post.
Mate not sure if you realise it, but 90% of your answers on this forum start with rude comments. Sort it out. KMA Originally Posted by: doggy  Originally Posted by: Kristoph  What values are you actually trying to capture?? Pretty obvious ;-) 3 different string values from a title to combine into a (time)string for a countdownchange but missing the concept of Concatenation of string variables with strings into one string. Hence the advice to do some research on vb.net programming (giving a fish versus teaching to fish).
 1 user thanked Kristoph for this useful post.
Joined: 11/23/2020(UTC) Posts: 241  Location: Wichita Thanks: 11 times Was thanked: 31 time(s) in 27 post(s)
Originally Posted by: WaltG12  Originally Posted by: doggy  giving a fish versus teaching to fish In this scenario, you're doing neither. Concatenation in VB is done using "+" So txA + txB + txC will concatenate those three variables.
 1 user thanked Roy Sinclair for this useful post.
Joined: 3/3/2022(UTC) Posts: 1  Location: 3067 Wood Street Saginaw, MI 48607
Originally Posted by: Travis9577  3 different string values from a title to combine into a (time)string for a countdownchange but missing the concept of Concatenation of string variables with strings into one string. Same link as above (see step 3) https://thedeveloperblog.com/vbnet/string-concat-vbnet
excuse my ignorance, I graduated in programming technician around the year 1999 but I didn't work in the area, I did it because I like programming
But I don't work in the area, I'm in civil engineering, in the pandemic I moved to a company that uses Vmix, so I've already done a lot of automation with the little knowledge I have and with the help here.
I studied the topics, which led me to do a lot of things.
I'm not looking for FISH, I'm asking for help to solve a problem and an idea that I had here at work, that's all.
If anyone can help, great, I'm grateful, but if you don't have the availability or desire, just say nothing, sending me to study programming is not helping at all.
I AM VERY GRATEFUL TO EVERYONE WHO TRYING TO HELP...
THANK YOU VERY MUCH
Originally Posted by: Kristoph  What values are you actually trying to capture?? I can capture the values that are in a gt title, example: txA=01 txB=15 txC=00 What I need is to take these values and transform into txA:txB:txC = 01:15:00 Take these values and format as time I can capture these values, I just can't join them in time format
Consegui. Obrigado pela atenção de todos
I achieved. Thank you all for the attention
API.Function("SetText",Input:="65",SelectedName:="Message",Value:=txA+":" + txB+":" + txC)
