nagendransm
#1 Posted : Saturday, June 7, 2014 3:30:55 AM(UTC)
nagendransm
I have decklink hd extreme 3d+ card vmix will support or not please reply me
nandhitv
#2 Posted : Saturday, June 7, 2014 4:22:55 AM(UTC)
nandhitv
nagendransm
#3 Posted : Saturday, June 7, 2014 4:27:43 AM(UTC)
nagendransm
But there is only extreme 4k is mentioned but the product I got is discontinued extreme hd 3d+
#4 Posted : Saturday, June 7, 2014 8:49:28 AM(UTC)
@ nagenransm
By all indications, the card works, but I would suggest not as a 3d input (I don't think vMix supports 3d).
Check out some previous threads:
http://forums.vmix.com.a....aspx?g=posts&t=2211
http://forums.vmix.com.a...t.aspx?g=posts&t=630
http://forums.vmix.com.a...t.aspx?g=posts&t=542
nagendransm
#5 Posted : Saturday, June 7, 2014 8:57:01 AM(UTC)
nagendransm
Thanks dude and I have an another question
Is that card support realtime hdmi(HD) input and downconverted sdi(SD) output at the same time.
Guest (4)
