Larsthiemo
#1 Posted : Tuesday, January 25, 2022 6:50:36 PM(UTC)
Larsthiemo
Netherlands
Hi all,
I'm looking for a way to set a fixed transition for an input. So no matter in what scene you are, what button you press, when you try to switch to a specific input it automatically uses the Merge transition.
Is there a way to implement this into my vMix production?
Thanks in advance!
#2 Posted : Tuesday, January 25, 2022 7:06:42 PM(UTC)
Originally Posted by: Larsthiemo Go to Quoted Post
Hi all,
Thanks in advance!
What is wrong with a simple shortcut merging that specific input ?
Larsthiemo
#3 Posted : Tuesday, January 25, 2022 8:20:44 PM(UTC)
Larsthiemo
Netherlands
We use a third party software that communicates with other software, but that software won't let us make more adjustments then pushing a specific input into prgm.
Edit: Also good to know that everything is automated, there is no button touched for this instance.
#4 Posted : Tuesday, January 25, 2022 8:22:49 PM(UTC)
in what way does it do that , how does it send that command? how is that related to you pushing any button ?
Larsthiemo
#5 Posted : Tuesday, January 25, 2022 8:34:35 PM(UTC)
Larsthiemo
Netherlands
To be honest, I dont know what command that software sends to vMix.
I do know that it communicates using the vMix Web Controller.
#6 Posted : Tuesday, January 25, 2022 8:43:10 PM(UTC)
Bit sad they can't change the cut to pgm into a merge to pgm , it shuldnt be that hard
