Hi all,
I'm looking for a way to set a fixed transition for an input. So no matter in what scene you are, what button you press, when you try to switch to a specific input it automatically uses the Merge transition. Is there a way to implement this into my vMix production?
Thanks in advance!
Thanks in advance! What is wrong with a simple shortcut merging that specific input ?
Originally Posted by: doggy  What is wrong with a simple shortcut merging that specific input ?
We use a third party software that communicates with other software, but that software won't let us make more adjustments then pushing a specific input into prgm. Edit: Also good to know that everything is automated, there is no button touched for this instance.
in what way does it do that , how does it send that command? how is that related to you pushing any button ?
Originally Posted by: doggy  in what way does it do that , how does it send that command? how is that related to you pushing any button ?
To be honest, I dont know what command that software sends to vMix. I do know that it communicates using the vMix Web Controller.
Originally Posted by: Larsthiemo  Originally Posted by: doggy  in what way does it do that , how does it send that command? how is that related to you pushing any button ?
To be honest, I dont know what command that software sends to vMix. I do know that it communicates using the vMix Web Controller. Bit sad they can't change the cut to pgm into a merge to pgm , it shuldnt be that hard
