spinfold
#1 Posted : Sunday, January 23, 2022 8:04:26 PM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
I know that I can set the preview and program for Mix 2, 3 and 4 using the PreviewInput and ActiveInput shortcuts, but that only accepts an input number. I'd like to be able to setup two buttons to go backwards and forwards through the drop down lists in a Mix input.
I thought PreviewInputNext and PreviewInputPrevious shortcuts would do this, but - unlike similar shortcuts - you cannot specify which mix you want to change so are stuck with only Mix 1, the main output.
#2 Posted : Monday, January 24, 2022 1:37:35 AM(UTC)
Untile request granted
quick solution :
- Set shortcut PreviewInput with Input to Hover and Mix to the one you want
- Alternativly script that adjusts a dynamicinput value based on current value to then perform the same a above but with DynamicX as input
