Feature Requests
PreviewInputNext and PreviewInputPrevious shortcuts for Mix 2, 3 and 4
Joined: 1/23/2022(UTC) Posts: 132  Location: Milton Keynes Thanks: 14 times Was thanked: 14 time(s) in 14 post(s)
I know that I can set the preview and program for Mix 2, 3 and 4 using the PreviewInput and ActiveInput shortcuts, but that only accepts an input number. I'd like to be able to setup two buttons to go backwards and forwards through the drop down lists in a Mix input.
I thought PreviewInputNext and PreviewInputPrevious shortcuts would do this, but - unlike similar shortcuts - you cannot specify which mix you want to change so are stuck with only Mix 1, the main output.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Untile request granted
quick solution :
- Set shortcut PreviewInput with Input to Hover and Mix to the one you want
- Alternativly script that adjusts a dynamicinput value based on current value to then perform the same a above but with DynamicX as input
Feature Requests
