iceltv
#1 Posted : Saturday, January 22, 2022 9:00:38 PM(UTC)
iceltv
Turkey
Hai there.
I have a little problem. and I want to believe its a software issue not hardware thing.
The place i work on using "StreamLabs MH4L" SDI card. it looks like cheap Decklink Duo 2 rip-off but still worked good.
Anyway it has something like this: Strange Flickering
image moving like unstable surface or stabiliy issue in vmix.
I don't remember when it started but I have to fix this.
I have vmix 21.0.0.60 and w10 PC
#2 Posted : Saturday, January 22, 2022 10:15:01 PM(UTC)
You have been a member since:: 12/27/2012(UTC)
Originally Posted by: iceltv Go to Quoted Post
Hai there.
If you believe it is a software issue why haven't you update vMix yet , we are almost at 25 ! v21 was released 4 years ago !
iceltv
#3 Posted : Sunday, January 23, 2022 12:14:36 AM(UTC)
iceltv
Turkey
Simple, upgrading newer version requires money. In terms of money, I don't have any
#4 Posted : Sunday, January 23, 2022 12:50:19 AM(UTC)
Yeah right, running PRO right? What do you use vMix for then ?
You haven't even updated you v21 to the latest v21 which costs nothing
Of course one can alsways ask vMix support directly but you would need a lisence key
iceltv
#5 Posted : Sunday, January 23, 2022 1:28:34 AM(UTC)
iceltv
Turkey
No I have HD Licence for latest version 21.
look if you know something TECHNICAL about this issue. Im here to listen otherwise just don't say anything.
#6 Posted : Sunday, January 23, 2022 1:36:32 AM(UTC)
21.0.0.60 is not the latest v21, scroll down this page for a download https://www.vmix.com/software/download.aspx
As I said , https://www.vmix.com/contact-us.aspx is a good place for resolving such issues but would need more information too like what is your setup for example , inputs , driver updates for the card, camera used and so on
The knowledge bases is also a good resource https://www.vmix.com/kno...-flicker-on-some-laptops
