Hai there. I have a little problem. and I want to believe its a software issue not hardware thing. The place i work on using "StreamLabs MH4L" SDI card. it looks like cheap Decklink Duo 2 rip-off but still worked good. Anyway it has something like this: Strange Flickeringimage moving like unstable surface or stabiliy issue in vmix. I don't remember when it started but I have to fix this. I have vmix 21.0.0.60 and w10 PC
Originally Posted by: iceltv  Hai there. I have a little problem. and I want to believe its a software issue not hardware thing. The place i work on using "StreamLabs MH4L" SDI card. it looks like cheap Decklink Duo 2 rip-off but still worked good. Anyway it has something like this: Strange Flickeringimage moving like unstable surface or stabiliy issue in vmix. I don't remember when it started but I have to fix this. I have vmix 21.0.0.60 and w10 PC If you believe it is a software issue why haven't you update vMix yet , we are almost at 25 ! v21 was released 4 years ago !
Simple, upgrading newer version requires money. In terms of money, I don't have any
Originally Posted by: iceltv  Simple, upgrading newer version requires money. In terms of money, I don't have any Yeah right, running PRO right? What do you use vMix for then ? You haven't even updated you v21 to the latest v21 which costs nothing Of course one can alsways ask vMix support directly but you would need a lisence key
No I have HD Licence for latest version 21. look if you know something TECHNICAL about this issue. Im here to listen otherwise just don't say anything.
