sacchin
#1 Posted : Saturday, January 22, 2022 8:08:04 PM(UTC)
sacchin
Hi all!
I hope this isn't a silly question!
I have a Blackmagic Decklink Duo 2 which I use to connect 2 SDI cameras (Sony PXW-X70).
I understand this capture card has 4 inputs and 1 is a reference in.
I use channels 1 and 2 (I think) for video capture.
I want to use the other 2 channels as well (2 more cameras) however I am struggling to understand how the inputs work.
I was watching this -
The guy talks about the 4 channels however he explains something about the connectors that are paired. Any ideas what this means please?
I dont have 4 cameras atm but looking to add these but before I do, I want to make sure my capture card can accept 4 inputs.
I ust vMix software to stream.
Also any recommendations on using a HDMI capture card as well as this SDI to add more inputs such as an SLR camera with no SDI.
xaver
#2 Posted : Saturday, January 22, 2022 10:26:29 PM(UTC)
xaver
open BMD Desktop Video Setup
there goto "Connector Mapping" for all 4 Inputs
4:26 in the YT Video
you have to seperate all 4 SDIs
xaver
#3 Posted : Saturday, January 22, 2022 10:34:02 PM(UTC)
xaver
I prefer a HDMI to SDI Converter, so you can use longer cables
Peter1000
#4 Posted : Sunday, January 23, 2022 5:57:21 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
see here
Duo2 settings.PNG (116kb) downloaded 14 time(s).
thanks 1 user thanked Peter1000 for this useful post.
nikosman88 on 1/24/2022(UTC)
nikosman88
#5 Posted : Monday, January 24, 2022 8:47:50 PM(UTC)
nikosman88
Greece
Hello. When you say "vmix overwrites the videostandard" means that if we have for example in vmix a 576p preset and in blackmagic desktop setup we have 1080p, when we use external from vmix it will be 576p?
xaver
#6 Posted : Monday, January 24, 2022 8:59:16 PM(UTC)
xaver
AFAIK this depends on the firmware of the BMD Device
normaly yes, but it's better you also set the output ind the BMD Setup you need
thanks 1 user thanked xaver for this useful post.
