Accidentally discovered a new interface glitch
Joined: 9/13/2016(UTC) Posts: 118   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
Hi everyone, I haven't posted in a while and here it is! Accidentally discovered a new interface glitch. When exactly this happened - I can’t answer. I didn’t have to change the interface for a long time, but a new person came and it was necessary to make changes. The bottom line is (everything is clearly shown in the video) there are certain settings in the interface - 3 physical PTZ cameras and for each of them a set of virtual inputs with coordinates. When changing the size of the working windows of the interface, all settings and coordinates of virtual inputs stop working (the link of the cameras is not lost, this is the first thing I checked). When you return the size of the windows to their original size (in which the project was created), everything works again. All of this was captured on video... A very unpleasant moment that spoils the workflow https://youtu.be/3ry9qKd8GQAhttps://youtu.be/3ry9qKd8GQA
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
Joined: 1/13/2010(UTC) Posts: 5,364  Location: Gold Coast, Australia Was thanked: 4784 time(s) in 1641 post(s)
vMix generates PTZ thumbnails at the resolution set at the time in Settings -> Display. if this is changed after, then you will need to re-create the PTZ inputs as the size has changed.
