Shortcut question using Stream Deck
I am creating shortcuts and using Stream Deck for two different presets (two different operators). I created the first set of shortcuts and saved the preset, I will call it PS1. I then opened up the second preset, PS2, and created several shortcuts, using the same structure as PS1 for several of them. I have one shortcut for PS1 that works as it should, but PS2 does not operate the same. I have checked several times but am not sure what is going on. PS1 has two shortcuts with the same button. I want to turn on Fullscreen, then open an input onto the fullscreen. The input is a laptop. Here are the shortcuts
Key: F1 Function: Fullscreen
Key: F1 Function: SetOutputFullScreen Input: 2 Laptop (Leave box unchecked - assign shortcut to input number) Value: (empty)
Note: PS1 leaves Value empty in second shortcut. I tried leaving it empty in PS2 and also putting a "2" for the value, without success.
The problem is that PS1 will work correctly and will turn off the fullscreen if the button is pressed a second time. PS2 will stay on when the button is pressed a second time. Ideally I would like PS2 to have the fullscreen turned off after a second press, but no matter what I try it does not work. Any ideas?
Let me ask the question another way: Why do I get different results using SetOutputFullScreen in shortcuts on different presets?
