What is the Maximum Input Trigger Delay Value
Joined: 4/3/2020(UTC) Posts: 21  Location: Severn Thanks: 2 times
Good-day Folks,
Earlier today, I attempted to do some automation on a small livestream production for my church. What I tried to do was to use a the OnTransition trigger of a countdown video to play another video roughly 52 seconds after the countdown has started. Basically, all I'm trying to do is play a video file with a duration of 4:08 at the exact time that will cause it to end when the countdown ends. For my livestream that starts at 5:30AM, my calculation showed that I should start playing the file at 5:25:52. So I set out to get my triggers setup on the countdown video and everything was working fine, except that I noticed that the delay I had applied on the OnTransition:Play trigger of 52000 milliseconds was always getting trigger at 30000 milliseconds (30 seconds).
Is there a hard limit for the delay value?
Joined: 12/27/2012(UTC) Posts: 5,515  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Thanks for the quick response. I will govern myself accordingly and see if I can accomplish this using a Playlist. Never thought about using the playlist like this, but if Martin suggests it, then it's worth a shot. Wish you a blessed day, thanks again.
