kismetgerald
#1 Posted : Tuesday, January 18, 2022 2:49:12 AM(UTC)
kismetgerald
Good-day Folks,
Earlier today, I attempted to do some automation on a small livestream production for my church. What I tried to do was to use a the OnTransition trigger of a countdown video to play another video roughly 52 seconds after the countdown has started. Basically, all I'm trying to do is play a video file with a duration of 4:08 at the exact time that will cause it to end when the countdown ends. For my livestream that starts at 5:30AM, my calculation showed that I should start playing the file at 5:25:52. So I set out to get my triggers setup on the countdown video and everything was working fine, except that I noticed that the delay I had applied on the OnTransition:Play trigger of 52000 milliseconds was always getting trigger at 30000 milliseconds (30 seconds).
Is there a hard limit for the delay value?
#2 Posted : Tuesday, January 18, 2022 3:01:20 AM(UTC)
kismetgerald on 1/18/2022(UTC)
kismetgerald
#3 Posted : Tuesday, January 18, 2022 3:48:56 AM(UTC)
kismetgerald
Thanks for the quick response. I will govern myself accordingly and see if I can accomplish this using a Playlist. Never thought about using the playlist like this, but if Martin suggests it, then it's worth a shot. Wish you a blessed day, thanks again.
