GT
GT Title Reload Problem
Joined: 1/14/2022(UTC) Posts: 3  Was thanked: 1 time(s) in 1 post(s)
I have been learning Vmix and so I have my GT file imported in, and I'm able to connect Vmix to Google Sheets. Once I connected it to the text I need to update on Google Sheets, the input goes completely black. Once I reload the input, it shows back with the information, but I need to figure out what's causing it to go black so I can prevent it from happening during live productions.
Thanks for any help!
Joined: 10/22/2016(UTC) Posts: 25   Location: Lucca, Italy Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Originally Posted by: doggy  https://www.vmix.com/knowledgebase/article.aspx/200/gt-inputs-show-up-as-blank Unfortunately, that's not the issue. But I do appreciate the help. I think I fixed it but will update if so.
Originally Posted by: meremultimedia  +1 So I figured it out, well for my situation. Make sure that there is only one input of the gt title that you are using. Apparently there was a duplicate but it got messed up and it was effecting my actual input that I was using. I hope you find your answer too!
 1 user thanked KmizeBH for this useful post.
GT
